Page 7 of 8
FirstFirst ... 5 6 7 8 LastLast
Results 181 to 210 of 235
    Oct 2016
    Romania
    Hi Cauptain
    I can send to you in private the answer from HDFury support team if you want
  2. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Originally Posted by cimburel View Post
    Hi Cauptain
    Thank u cimburel. I want.
    Claudio
  3. Member Seeker47's Avatar
    Jul 2005
    I recognize that this thread deals almost entirely with the Avermedia products. I've seen a used H727 model on sale recently . . . but I think the models more often discussed here began with a "C" ? Also competing products -- either in expansion card or standalone box form factors -- from INOGENI, Magewell, Black Magic Intensity and others. One User / Reviewer said that he had tried several different solutions, and Avermdeia was the only one that worked for him. At the high end, there is also the HD Fury. How do you distinguish relative capability among these ? (Particularly if cost is not the deciding factor.)
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
  4. Hey guys, I am at a loss.
    I recently picked up a GC513 (Live Gamer Portable 2 Plus) and I CANNOT get it to broad cast ANY images from my PS4. I have tried PC and No PC with no luck. I have also reinstalled the software numerous times. Only once did I get some sort of image, it was a broken image on the capturing program and it just flickered on and off for a few seconds, then went back to "No Signal". At this point I am not really sure what to do other than return it and pick up an El Gato.
    Any suggestions?
  5. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Any suggestions?
    Easy. Go to PS4, settings, vídeo and set HDCP off. Only this.
    Claudio
    Enviado de meu Moto Z2 Play usando o Tapatalk
  6. I did that, one of the first things that I did. Still nothing.
  7. Member Seeker47's Avatar
    Jul 2005
    A Bump to my post #183, above.
    & incidentally, I got this 20% off sale notification from Monoprice
    https://www.monoprice.com/search/index?keyword=hdfury&cl=res&utm_source=190125_email&u...eryName=DM5683
    though in the back of my mind there is something about only hobbled units being allowed for sale in the U.S.: to get fully capable ones that had not been messed with, you had to order from the source abroad, then take your chances with customs (?) But my memory on this could be off, or that could be out-of-date info . . . .
    Feb 2019
    Portugal
    Hi
    Is there any way to add the h.265 (my only have h.264)?
  9. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Originally Posted by nelsonpdf View Post
    Hi
    The easy way is using BANDICAM app.
    Download and install X265VFW: https://codecpack.co/download/x265vfw.html
    Use SOURCE mode, select Avermedia Card, configure AVI to X265/MPC and record.
    If you have a GTX card like 1050 or above, record using default engine. Its have H265 encode option.
    Claudio
  10. Member Sionisti's Avatar
    Mar 2019
    Finland
    would this work with my LGX? the program doesnt seem to recognize the LGX
  11. Does anyone have an update as to whether this ViewHD splitter still works for stripping HDCP from regular HD 1080i or 720p video?
  12. Member Seeker47's Avatar
    Jul 2005
    It may depend on when you bought it, since I don't know if the same exact unit(s) have been continuously manufactured and sold ? I got mine -- with two ports and I think also at least one with four -- well over three years ago, at a time when there was much confirmation on them here, and I have not upgraded any of the tv or satellite gear since then. But, YMMV.
  13. Thanks. You know it's interesting. If you sort the Amazon reviews by most recent, the ViewHD splitter seems to still strip HDCP for most reviewers as recently as this month. It's hard to tell exactly which HDCP version is being stripped by each reviewer, but the general sense I get from the reviews is that it will not strip HDCP 2.2 but will strip earlier HDCP versions.
  14. Hi Claudio.
    What should i use for the gc311 live gamer ?
  15. I have tried the above files but I am getting this message
  16. Originally Posted by Seeker47 View Post
    I can confirm that the currently available 2 port ViewHD splitter does indeed work. It's the real one that says ViewHD on the device although DCeric posted earlier in this thread in Sept 2018 that a different brand worked as well. Keep in mind the DVR I'm working with is circa 2012 so I'm probably only dealing with HDCP 1.3 or 1.4, but it does still work for that.
  17. I just got one of these. The previously mentioned one was only in the US store and this one had recent reviews suggesting it would work. It works fine to get around HDCP and let me capture from HDMI from my Sony HDD/DVD recorder. As with the previous post, no idea if this will work with more recent hardware.
  18. Member Seeker47's Avatar
    Jul 2005
    Is this a U.K.-centric model (with SCART) ?
    It would be good to find out about any splitters that strip out HDMI and which work with more current iterations of HDCP hardware. ( > 1.4, I guess.) If such even exist. Or maybe that's back to the Fury, for which I find the descriptions of their current models rather confusing.
    I'm going to have to re-bump my never answered post #183 above: it would be great to have some guide / listing to the Avermedia models that are still available, which will work with the software discussed in this thread. (I think I would favor the standalone boxes over capture card options.)
    I have recently come across some interesting looking, purportedly HTPC-alternatives that are far more compact than any of the hardcover-book-sized SFF models that Shuttle has made to date. (I suppose that Raspberry Pi and the small NUC boxes have paved the way for this.) It may have some degree of overlap with the objectives of this thread, but probably demands its own thread. Based on the lack of response to some of my threads posts here, I'm wondering if this might garner more discussion over on AVSforum . . . .
  19. I just wanted to report that the currently available (on Amazon UK) Wingoneer 2 Port HDMI Audio Video v1.3b 1080p 3D Splitter for HD TV PS3 PS4 Blu-ray 1 in 2out (UK Plug) did NOT strip HDCP 1.3/1.4 and allow capture despite some reports that earlier 2014-2016 versions of this splitter did strip it. At least it did not work for me in the US. I tested both output ports. It would allow video through to the capture card, but when I tried to record, my capture card would give me an HDCP warning and would absolutely not allow any recording. Thus it seems to function well as a splitter but not as a stripper.
  20. Originally Posted by Seeker47 View Post
    It's a RDR-HX750, there are both PAL and NTSC variants. Not specific to any country other than maybe the tuners. I use it for grabbing video from video tapes though.
    Mar 2016
    Brzil - Distritu Federal
    eu não estou conseguindo fazer live pelo facebook pelo RECENTRAL coloco as coisas para fazer e a conexão não é feita alguém pode ajudar?
    I am not able to do live by by RECENTRAL put things to do and the connection is not made can somebody help?
    https://files.videohelp.com/u/253255/Captura%20de%20Tela%20%28117%29.png
Name:	Captura de Tela (117).png
  22. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Hi carlosg125BR,
    You have installed stream engine?
    Link: LGP_Stream_Engine_V1.3.0.17_Build18101001
    Facebook app has changed the way to connect stream last month
    Try OBS instead RECENTRAL if fail. Stream engine is very necessary to this.
    Claudio
  23. Member
    Mar 2016
    Yes I have this LGP but I did not want to use the obs did not want the RECENTRAL even more that in it I can not select pc or consoles
  24. If I buy the hd vertex splitter will it allow me to remove the hdcp for PS3/PS4 game recording without me going and disabling hdcp and enabling it for streaming apps? Also will it be able to remove 2.2 hdcp? What i am ultimately asking does it remove hdcp or just converts it from 2.x to 1.4?
  25. Hi! I am new to streaming. I bought the AverCapture card GL310. I want to use streamelements OBS to stream to YouTube. I am connecting my iPad Pro to an apple dongle, and then the dongle into the capture card. Then the capture card to my PC. When I open OBS I get a black screen (while running stream engine). Also, in RECentral, I can see my iPad home screen but if I click the record button, I get the copyright error. Can anyone help? Thank you!
    -T
  26. Hi there, is there any chance you can update the drivers for the U3 card, since they don't work with the Windows 10 1803 update properly. If I use the official updated driver (3.0.64.118(Beta)) there is video but no audio.
  27. Member
    Apr 2012
    Portugal
    I just updated my win 10 to lastest updates and the Avermedia RECentral 1.3.0.116 version stopped and doesn't work anymore..
    Do you know what is going on?
    Win 10 1903
  28. Give the "app" access to your "camera".
  29. Hi.
    I try to make things working with Live Gamer Portable 2 plus GC513 and cannot manage to do it.
    With Re Central 4.0 everything is fine.
    With Re Central 1.x it can't see my device.
    [Attachment 50950 - Click to enlarge]
    What i am doing wrong ?
    Ps: i did install drivers.
  30. Member
    Mar 2016
    eu estou a procura do programa avermedia pc free para a placa live gamer portable alguém sabe onde acho pois a avermedia removeu do site e gostaria de usar esse programa novamente para reconfigura minha placa no modo pc free para grava em 1080p pelo cartão de memoria alguém sabe onde posso conseguir?
    i'm looking for the avermedia pc free program for the live gamer portable card does anyone know where i think because avermedia removed it from the site and would like to use this program again to reconfigure my card in pc free mode to record in 1080p using the memory card does anyone know where can i get it
